Supplier of large piston rings
Verfasst: Fr 27. Feb 2026, 11:49
von olNick
Hello,
I am Nikos, from Crete and this is my first post here.
Can someone recommend a European supplier for piston rings, reasonably priced.
I am looking at rings of 120mm bore diameter, by 6.3mm (0.250").
Modern rings at this diameter are usually much thinner, max 3mm thick.
This is for a single cylider, semi diesel, Bolinder "Greek clone" from about 1920
More or less like this, but without the reversing gearbox
Photo here
https://commons.wikimedia.org/wiki/File ... 412%29.jpg
Re: Supplier of large piston rings
Verfasst: Fr 27. Feb 2026, 12:34
von WolgaV3
Hi Nikos,
I haven't had any work done there myself, but jfk-rings.com is one option in Germany. There's also a company in Enschede, Netherlands, but they're expensive too. www.thn.nl
Verfasst: Di 3. Mär 2026, 11:36
von olNick
Thanx, I'll give it a shot...
regards,
nick
Verfasst: Di 3. Mär 2026, 18:43
von Standuhr
Hello Nick,
i found some here 12 to 200 mm!!
https://de.dlastore.com/zylindern-kolbe ... ringe.html
Regards Klaus
