Farymann D 20 Technical specifications
Hello!
I have a D 20 f Farymann engine.I know about this engine:The Farymann Diesel engine type 28 D20 0048 n=1800 RPM is a horizontal air cooled 1-cylinder direct injected 4-stroke Diesel engine,
year of build 1974.
Output approx. 8 HP at 1500 RPM
The production of D20 engine type was ended in 1979.
I would like if you can help me with some technical specifications.
I want to know if the piston matches and the segments go by tractor? And cuzines(roller bearing), biela (the connecting rod), arbor (Crankshaft).Thank you.
year of build 1974.
arturwernz
farymann k64 6ps 3000
Re: Farymann D 20 Technical specifications
Hello,
what Piston do you mean and which segments? I have the complete technical sepcifications here and also can provide all parts to this engine.
Hi! Piston(kolben), segments(bremsbackn-enheit).I hope this is the technically correct translation.The first picture are segments ,the second picture is a piston.arturwernz hat geschrieben:Hello,
The pictures are informative only is not what I am looking for.
- download.jpg (3.89 KiB) 3909 mal betrachtet
- images (1).jpg (3.93 KiB) 3909 mal betrachtet
arturwernz
Hello,
i don´t understand what do you want. The Piston needs to be 90mm diameter. Do you need a new Piston with piston rings (segments) or only the Piston rings?
I'm looking for technical data about the piston, and cuzines(roller bearing), biela (the connecting rod), arbor (crankshaft)And I want to see if they matches from tractor 445.
arturwernz
Good Morning,
could you send me your adress, I can send via letter post the documents.
So you can find out what you need.
BR
Artur Wernz
BR
Artur Wernz
arturwernz
Hallo Doro,
hier die gewünschten Bilder.
Gruss
Artur
Gruss
Artur
- 02_20180410_140141_resized.jpg (75.41 KiB) 3636 mal betrachtet
- 04_20180410_140129_resized.jpg (77.15 KiB) 3636 mal betrachtet
- 01_20180410_140149_resized.jpg (90.8 KiB) 3636 mal betrachtet
- 05_20180410_140119_resized.jpg (83.85 KiB) 3636 mal betrachtet
- 03_20180410_140135_resized.jpg (95.92 KiB) 3636 mal betrachtet
Thank you very much Artur! Have a nice day!
Below is a link to the engine in operation:
https://www.youtube.com/watch?v=m2g0rc6XdO0
https://www.olx.ro/oferta/motor-faryman ... b6efcdc8ca
