Deutz mah711 age
ribbo
Deutz mah711 age
Beitrag von ribbo »
Hello everyone.
Sorry my German is very very poor ( I rely on google translate). I have a deutz mah711 stationary engine which I am restoring. It is missing its serial number plate....but I have found a hand stamped number on the back of the crankcase casting 583591 and wonder if this is the serial number rather than a casting number. Can anyone help please?... I would love to know it's age.
Thanks
countryman
Re: Deutz mah711 age
Beitrag von countryman »
The number on the crankcase is indeed the engine number. Yours was built 1938: http://www.maschinenmuseum.de/DEUTZ/DEUTZ_NR.HTM
Mine is from the same year, 592270: viewtopic.php?t=8891
countryman
sorry, mine is from 1939.
ribbo
Beitrag von ribbo »
Many thanks....that's brilliant thank you! (I have had no help in uk...and had virtually given up until finding this forum). Mine doesn't have a dipstick at all ( no provision on crankcase). Was this normal please?
ribbo
Beitrag von ribbo »
It also has no speed control lever. Am I correct with speed? It's running at 1500rpm. Thanks
ribbo
Beitrag von ribbo »
Sorry...another question. Am I correct that oil capacity of crankcase sump should be 2 litres?
Hello
ribbo hat geschrieben: Mo 14. Aug 2023, 08:41 Mine doesn't have a dipstick at all ( no provision on crankcase). Was this normal please?
The normal version should have a dipstick.
Dipstick Deutz MAH 711
The engine was available with different speed settings (different governor springs). 1500 rpm is the usual speed.
Engine Speed Deutz MAH 711
Yes, the manual says 2 litres (max. oil level, min. oil level is 0.8 litres less:
Oil capacity Deutz MAH 711
best regards
ribbo
Beitrag von ribbo »
Many thanks for your help.
countryman
Here you find the manual and spare parts drawings for your engine as a free download:
https://www.feldbahnseite.de/archiv/dat/strue_mae.pdf
Google (Google lens?) may help translate.
ribbo
Beitrag von ribbo »
Many thanks for the link.... yes , I'll try translating with Google translate.
